Brokeneagle
This 'bricked -up' toughie is already started and coming soon to a channel near you ........
I searched out as many shots of this tank as I could find - some have been taken at different times if you look at the slogans painted on the barrel and the side rubber sheet hanging out with the Kontakt brick barley attached. Also the last photo has no mud jammed in the tracks, which means it has travelled further on a hard surface.
This is an A in the same column...[which I may end up doing as well]
...and I think this is the same tank much later...
