MODERN RUSSIAN ARMOUR - T-72B1 in Ukraine April 2022
Brokeneagle
This 'bricked -up' toughie is already started and coming soon to a channel near you ........:dude:
I searched out as many shots of this tank as I could find - some have been taken at different times if you look at the slogans painted on the barrel and the side rubber sheet hanging out with the Kontakt brick barley attached. Also the last photo has no mud jammed in the tracks, which means it has travelled further on a hard surface.
This is an A in the same column...[which I may end up doing as well]
...and I think this is the same tank much later...
Here we go again, another version of the T-72, this time its an early B version, the B1.
The T-72B, which appeared in the mid-1980s, included a more advanced fire control system, the ability to launch anti-tank guided missiles [ATGMs] through its main gun and enhanced armor protection. The T-72B1 was a cost-reduced version lacking missile capability but retaining most other improvements.
The main changes are with the Kontakt armour bricks - they are smaller and cover the whole turret, as well as the front glacis plate and up to half way along the side skirts toward the rear. The rear of the tank has a few minor changes from the later models with some foldable armoured covers and rear louvre covers for the outlets. The right hand exhaust outlet is slightly different also. The spare track stowage configuration on the lower rear plate is also different.
This one is the Meng B1 kit, which is quite nice but has some painful aspects in and opposite way to the Trumpeter BA. I will get into that later.
What's with the green wheel? Just curious as it looks to be the same pattern as the others. Yeah, I know they mix and match patterns.
I decided to show the rear external fuel tank mounts folded as I was not going to have the fuel tanks on this one. This would require modifying the kit parts from the molded form to fit the tanks to folded back to the rear hull.
Here the mounts are shown on thisT-72 in the Ukraine.
I needed to cut the arc shapes off the base and turn them, adding holes and securing nuts to the bases. I also needed to cut away some of the molded detail from the arc arms that was additional to allow them to match the feul tank mounting grooves.
Similar Trumpeter parts showing the original form.
MENG PARTS - AFTER MODIFICATION
I added bolts to only 2 of the four holes in each base plate as I had seen in ref pics.
The seam lines you can see in the photo are nearly impossible to see with the naked eye - macro photo's always show upthe rough parts. One of my bases had some wonky holes but the mounting arm hides it well enough.
I next cut the front mud guards off as per the photos using a Tamiya razor saw, cutting at the section join line. This would require some additional work on 'scratching' up a wire spring arm to replace the molded plastic detail removed.
Next was the turret. Meng provide vinyl panels for the Anti- Radiation layer over the top of the turret. This was very hard to set in place but super glue finally proved the answer. The Trumpter BA version had an even more pain with the many attachment points having to be seperately fitted as PE detail.
I am not sure which was more difficult.
Fantastic work Ian. I dont recall ever seeing the mounts reoriented like that before, most seemed to have just been removed. Its a very eye catching detail though. Very nice.
Nice surgery Ian, those mounts could swing around either way on their pivots or were they just removed and reoriented?
Thanks MP. :)
No they didn't swing , they had to be removed and rebolted in the new position. I have seen many variations including bolting them on to just 1 edge of the base plate as in one of the plates on the 'pristine' tank displayed.
Evidence before us suggests Russian armored units run out of fuel quite often in Ukraine. This could explain it.
