Is it the Breda?Yeah the Panzer III is a big Beastie Tim. I think the 251 halftrack is a bit longer but not as wide. I picked up a Panzer 1 variant with a BIG gun a while back and it should be interesting.
Gonna need a bigger workbench.Now let's see what the Tiger looks like to those. It's amazing in 35 scale.
Thanks for making my mind up, PaulAs for the sag on the tracks, I would check references. IF I remember correctly on the panzer III's they don't have much sag if any. Remember these are considered medium tanks at best and they didn't have the track problems that the larger and heavier tanks had.
Bit of slack works as well and always looks a bit more real and dynamic, especially if you are going to beat it up a bit.Thanks for making my mind up, Paul. Tight tracks it is.
Yep. I like that lookBit of slack works as well and always looks a bit more real and dynamic, especially if you are going to beat it up a bit.
Good info RichB!German tanks used "dead tracks" that always showed some sag, even when brand new. When parked the sag can be seen between the return rollers and a slight sag between the drive sprocket and the first road wheel. When in motion the sag can be more visible between the drive sprocket and road wheel.
Over time the track will lengthen as the pins deform. Daily maintenance was to check the pins and adjust the tensioner to keep the track tension within limits. The drivers were also responsible to check track tension when stops and time permitted. Once the tensioner reached its maximum limit the crew could remove one or two links and adjust the tensioner back towards the minimum limit.
RichB
