paddy
A question I always face when thinking about a build is what sort of finish I should go for?
It’s a question that applies to most subjects but especially Vehicles IMHO
Thinking about a future Spitfire build do I go for a war weary realistic finish, a modern restoration type finish …..or a museum perfect finish.
Each has an advantage, War weary means you can hide a multitude of imperfections under weathering, paint and filler. Probably best used on those non perfect older models. That said weathering is a skill in itself and can go very wrong.
A modern restoration finish is what most people do and is pretty straight forward as its basically OTB with basic paint colours and gives a very presentable finish. Thats sort of what did with my SU27 build recently but probably not very realistic
Then there is what I call the museum quality with added detail and spit clean finish which can work well on cars and motorcycles.
Each finish presents its own problems for example I am a recent convert to the excellent MRP paint range, but it is a limited range at the moment and there is only one UK stockist. Another problem is you need a near perfect finish with these ultra-thin paint because even with 6 coats to cover they will not fill or hide gaps in fact if anything they highlight imperfections that a matt coat of Tamiya would cover.
Museum finish can present problems with not easy to replicate finishes like Chrome and aluminium type finishes and Mirror finish paint body colours..
So I wondered what do you prefer for your build and what advantages and disadvantages do your choices throw up ?
