phantom II
Entirely possible :frantic
You putting any parts together yet?![]()
There was work done! I removed the wire for the photo as I expect to spray on some color but Jon Tamkin (Mission Models' owner) warned me that I should only use his thinner. I need to buy it. So more work on the desert filter, landing gear (not shown), riveting and adding vents to front fuselage area...
Not much, but it is progress and it felt good to be at the bench if only for a few hours!
So, I added the lock slot, some panel lines, refined shapes, the button on the tip and prop blade bosses:
Well, Airfix made my conversion moot...That doesn't mean I will stop.
https://www.airfix.com/uk-en/news/workbench/new-spitfire-kit-joins-the-airfix-ranks
