roadwheels....![]()
Honestly, there are only a handful of detail errors that really bugged me on the finished kit; the biggest is the relation of the drive sprocket to the first return roller and anterior portion of the lower hull. This combined with a slightly undersized drive sprocket and oversized return rollers give a noticeable downhill slope to the track run from the first roller to the top of the sprocket. In Kit 6301 this is fixed. But I am going to describe a VERY EASY way to camouflage this. It is not a correction, but just a sleight of hand to make the parts appear in a better relationship.
Before we begin the discussion, I want to give a warning. This kit is like a Ferrari. It’s sleek, sexy, finely tuned and has super tight tolerances. But it also is temperamental, won’t take abuse well, and can be unforgiving. My advice is to become very familiar with the instructions, and to test fit EVERYTHING! This is not a kit to be rushed, it, like a fine wine, is to be savored and enjoyed. One other thing, be prepared for lots of exclamation points. This kit deserves them.
As molded, the final drive assemblies sit 2mm too low. This combined with the undersized drive sprocket and oversized return rollers, gives a noticeable down hill run to the track as it passes over the first return roller on its way to the drive sprocket. I have seen a couple different ways to fix this, some fairly complex. My fix is fairly simple, but is cosmetic only. What I did was to rotate the entire cover up about 2mm. You must then trim away the section of the bolt plate that is exposed. This moved the drive sprocket up, but also slightly forward. In my opinion this is not nearly as noticeable as the low position. It also changes the relationship of the armored cover to the hull front, but again much less noticeable.
lowers it to 7 on just a few..
Oh yeah, when it comes time to add the final drive housing, DO NOT FOLLOW THE DIRECTIONS!
Below is taken from my MMiR article on this kit.
Darn It! I already installed the drive housings!![]()
HA! I haven't even started to screw this up yet.
So is kit 6291 the same kit, I know it's a different model tank but I notice the part numbers are the same and it looks like the same PE (for the most part) is in the box.
