This build had taken me some time to put together. The base is a pic frame mount with poster board foam as ground base. The electronic ground concrete ground mounts and fence concrete rectangular blocks were both plaster cast and poster board foam cut and hot glued together. Then, I added wall Spackle to cover the joints. The signs were downloaded from the internet and scale to size using a similar WORD like program. The boom setup and detail around, were scratch built using styrene and misc. parts, from my box of tricks.
