Found a little bench time today, thought I'd post what went on. The brass machine gun barrels from RB are top notch and go together with little issue.
The one on the left is assembled, the barrel and shroud are separate pieces. I ran a drill bit through the shroud to allow the barrel to slide in place.
I added the kit stars to the turret and used a dab of Dr Mike's Glue to bond the tracks prior to installation.
Barrels in place temporarily.
I cut the barrel off the kit part and drilled a hole for the new barrel. A little Dr Mike's and good to go.
The upper hull is still not attached permanently until I weather a little further, but the brass really adds over the kit parts.
Stay tuned, if you dare!
:drinks
