While I am working on my Panzer 38 weathering I wanted to get another kit under construction.
I went with another Tamiya 1/48 Panzer II.
This is a really good little kit.
Only complaint is that the springs for the suspension are molded onto the hull. I will work around this.
The tracks are so tiny and finicky that I had to glue them onto the running gear to keep it from falling apart at the slightest touch.
I am also using RB Model 20mm and MG34 barrels. These were dirt cheap on Luckymodel and look way better than the kit parts.
One complaint about the 20mm barrel is that the base of the barrel is not there. I had to very carefully drill out the plastic part and fit it over the brass barrel. Fortunately for me this worked perfectly.
