ausf
Been staring at this box far too long after snatching it up as a preorder, can't wait to build...
The Italeri Vospers MTB. I did try to start this once, but was shorted a sprue. They only replaced it after sending them the box UPC as proof, so the length of time was enough to for me to lose fo c u s.......
Anyway, I'm planning on running this beast on three brushless motors, to get the proper scale movement.After waiting on the motors from Hong Kong, I slipped while pressing the shaft out (these motors are designed for planes and don't hsve an exposed drive shaft) and bent a housing. So while waiting on the new motor, I'm skipping my normal urge to box it all back up, andI'm moving astern to making rudders.
I copied the kit part in brass:
Mounted them, icluding the linkage for the servo. Once I mount the servo, I'll go ahead and glue this to the hull and thin coat the seams and connecting points with marine epoxy. One set, I'll add all the detail parts.
