Need to rant
As others have stated, it comes down to quality tools and the knowledge to use them. Invest in quality tools and practice with them. Until my wife swiped them away, I had Tweezerman tweezers and scissors (to cut PE free), and Wilder (as in Adam Wilder) tweezers.
What I use now are a set of Swiss tweezers I bought off eBay, Xuron PE scissors, a range of PE benders from The Small Shop, a superb bending brake (appropriately named The Fender Bender) from Ausfwerks [now OOP], and use various adhesives.
If the item to e glued is light with no stress on bare plastic, I have used Tamiya Thin Cement (green cap) to attach PE whose contact surface was roughed up with some sandpaper. If the items are painted, Gator's Grip Hobby Glue is perfect as it is tacky and one can remove the excess with water. note that now Kenny Loup, the man behind Gator's Grip Hobby Glue now offers two viscosities.
If items may come under some stress, then I decide if I should solder or cement. CA cement has poor shear strength, in those cases I use tiny dots of epoxy cement (a wasteful exercise as the amount mixed is always greater than actually used).
For soldering, I have several options. Obviously, I only use this to attach similar metals. Sometimes one must solder items real close to each other so I suggest looking at Chukw's SBS but one he hasn't shown is using high and low temperature solder. I use the high temperature solder on parts skipping items in between which I come back to with low temperature solder since it won't affect the high temperature (I use Tix brand) soldered joints.
For soldering, I have a Cold Heat product (sold in Radio Shack) for low temperature, a Wahl cordless soldering iron, or my American Beauty (thanks Ausf) resistance soldering set.
I used to sell aprons with two velcro strips to attach to the underside of the bench lip. It had an upside down warning on the front 'don't stand up' in English, French and German, It was kind of a joke item, but really was useful.
I own two, one is well used and the other still in its bag! Once again, thanks Ausf!
So what's where it went. :facepalm
I'm smoking it over. Between a Mill, Watchmaker Lathe or AB Resistance soldering station, I think I'll really get more use out of the Soldering station.
Where's the lace???
Tim, thank goodness there isn't any as Ausfwear wasn't too generous with the fabric and lace would get irritating when I model in the nude...
:sick:
Great...there was that speedo image I finally got over now this. :bang head
Something told me to avoid reading this thread...Too late!!
To be continue being inappropriate though...someone could add the " This thread is useless without pics" emoticon.
:rotf :rotf :rotf
(Sorry, had to!)
I find some PE parts are good but most of the small stuff is too 1 dimensional. I find I am picky which PE parts I use when I do get a PE set for a model!
True!! Working on my 1/72 PT-109 with the WEM pe set. I attached the mufflers & looked at the pe bits for it &decided not to use them. would've had to drill out the part & add a teeny-weeny piece that'll git covered in paint & hardly make a difference.
