jknaus
Administrator
From Wiki,
"BTR-60PU-12 (9S482) (punkt upravleniya) (1972) – BTR-60PB converted into an air defense command vehicle and used by units equipped with ZSU-23-4, SA-9 or SA-13. The turret was removed and the vehicle was fitted with the AMU telescope mast on the right side of the front hull roof and the AB1-P/30 1 kW generator on top of the blanking plate.[15] The vehicle is equipped with the 1G13 gyroscope, the KP-4 navigation apparatus and the ASPD-12 computer. Often, the PU-12 is connected to a radar and the radar image is directly visible on the vehicle's IT-45 monitor. BTR-60PU-12M can process up to 12 targets.
BTR-60PU-12M (9S482M) – Modernized model developed in the 1980s for units equipped with more modern SAM systems.[15] This model is equipped with the more modern ASPD-U computer instead of the ASPD-12 and with the S 23-1 data processing unit connected to the MP-21, MP-22, Strela-10M, Osa-AK etc. BTR-60PU-12M can process up to 99 targets instead of only 12.
Another vehicle for the recce shelf. Hope to finish gluing tomorrow and start painting.
Added a small piece of Albion tube to make a cannon plug for the antenna cable.
