New Year’s resolution – Get these Queens done!
Okay Bill some pictures
1) M50, parts box build
2) M1 Super Sherman, I just started back working on this one
3) M4A4A2
4) M4A4A2 FL10
5) M4A3E2
6) M4A4 Firefly Lebanese Army (I was told the engine deck was changed, so it is wrong. Never found pictures to change it or should I just finish it?
7) M1 Sherman M4A3 late welded hull
8) M1 Sherman M4A1 late cast hull
9) M32 kit bash (I started this 5 years ago, have not touched since)
10) M51
11) M4A2 Late
12) Sherman II
13) M4A3E4
14) M4A3 76mm
15) M4A1 76mm (turret has been damaged)
There is also the M50 APC I started, a M36, M10, M4A1 DV, M4A3 76mm, M4A3 75mm, M50-X3 and another M4A2 Late can't find the photos fast of them.
That is my unfinished Sherman list as on now. My plan is to finish a couple painted ones and a couple of unpainted ones for this year. I more than likely start a couple more to their places on the queen list.
4) M4A4A2 FL10
The FL-10 turret should have the shroud removed as it is a later feature than the turrets supplied by the French to the Egyptians. Otherwise, it is looking good!
To be different, check out this M4A4/A2 with the rounded final drive cover.
Lebanese Firefly.
Yet, yours is not wrong:
You have a lot more Shermans going on than I do!
Well thanks everyone. As you can see the bad thing about Shermans is they become wild :yipee
A big thanks to you Saul! I'm now going to order some track and knock the Firefly out! (y)
here is the picture I worked from;
Looks like Shermans are like rabbits. You put 2 unfinished ones away and when you open up the cupboard again there is 15 :D
All good projects guys.
For my Shelf Queens, check out my Maddog Manufacturing Thread for most of them. The rest are an R-100 Airship w/mooring tower, a Rebel Racer corvette car, a Revell Fishing Boat, and my Dora railgun.
Stay tuned for more pics!
This one has the modified deck. Did you order the decals from Military Modelcraft International?
Some links of interest:
https://milinme.wordpress.com/category/sherman/
http://www.militaryphotos.net/forums/showthread.php?126638-Lebanese-Army-Pictures&p=4260049&viewfull=1#post4260049
Regards,[/quote]
Thanks for the links. I hand painted the markings on mine. Did not know about any decals :facepalm
Nice review by the way. Just looking at that helps a lot. Now Does anyone have a spare Dragon M4A2 engine deck!
