I am SO certain that Tamiya has a VLR Mustang in the works. I bet they have a bunch of flashed over holes for all the various antenna arrangements on the fuselage spine. Can you check?
I'm going to make use of it because the AN/ARA-8 homing radio would have been mounted there. I have not found a clear picture of what that VHF set looked like, I have found some installation diagrams of how wire harnesses were run. There may be some modification of the radio rack, I think that's some sort of sump for the battery sitting there, most likely not needed if the radio is mounted there. This second radio also has locator pins on both the bottom and side.
missed your progress ... looks lovely!
i have to admit that i enjoy planes more and more!![]()
Grows on ya kinda like a virus! Treatment: build a T-72 :laugh:
That's rich coming from someone who did this...
bob, you don't know AMS until you read the response with suggestions over at the P-51SIG:
by hlppls45
First of all nice model
some minor nitpicks
1 the brake should be black not red
2 pipes are natural metal colored not black. Only the rubber parts are black
3 little black box next to oil tank was only used on D-5 NA and D-5 NT. Tamiya screw up
4 seat pad was chrome yellow. head rest should be dark forest green which will appear as almost black.
5 radio box needs to be turned around. Tamiya has it backwards.
Heads up items:
6. radio fitment will need some research. It appears that that the aircraft has been fitted with the an/ara-8 radio set which means that the equipment panels and boxes will be different. Tourist will know more about this area.
7. Use part d-28 shroud which should be the flat one. Do not use the ribbed shroud piece D-27 which is used for D-25,30 NA
and K-15 NT and later. FYI there were two different ribbed shrouds used but at this scale the differences would be small
8. piece d-5 k-14 control box is mounted on the right side of the shroud not the left as in the instruction manual and is oriented with the controls facing the left for last 200 D-20 and D-25 NA and the first 100 D-20NT.Instruction manual is correct for D-30 NA last 300 D-20 NT and all D-25 and D-30 NT aircraft.
9. Panel on the back of the armor plate is incorrect for all D models except D-30 NA,D-30 NT and possible some or all D-25 NT
10. Instrument panel and surround are completely fubarred. This is the one area of the kit where Tamiya completely dropped the ball. You did pick the correct parts for the aircraft you are modeling. Tamiya in trying to represent the various D-models completely hashed the panels and so many of the details on your panel are incorrect.
