Greetings Christian;
..... This seems to be a very confusing, and highly
debated subject among modelers. Part of the confusion
seem to stem from FW-190's that where up-graded in
the field. This is the conclusion to what I have found.
There where two Storm-Fighter up-grades made by the
FW-190 manufactures.
1. The FW-190/A8-R2
2. The FW-190/A8-R7
Field mods. where also done. One of these became
known as the FW-190/A5-U16.
..... There were three different field mods that
could be use on most any FW-190, thy consisted of:
1. Canopy... added armor to the windscreen, and
.. armored side plexiglass panels added.
2. Three armored side plates on each side of the
.. aircraft were added. These were place on the
exterior of the aircraft, around the cockpit area.
3. Armored plate was add to the bottom of the a/c.
...The plate covered the bottom of the cockpit.
The confusing part.... not all aircraft had all
three mods installed. Some had mods 1 & 2 installed
but not mod 3. They could be used separately, or
togather.
The manufactures up-grade on the FW-190/A8-R2
consisted of. Mods 1 & 2.
Note the three additional armor plate on the side
.... of the cockpit.
The most extensive up-grade was done on the FW-190/A8-R7.
This was also a manufactures up-grade.
Focke-Wulf FW-190 in action
Jerry L. Campbell & Don Greer
Squadron/Signal Pub... 1975.
The Focke-Wu if FW-190/A
Profile Pub. No.3......
Model Referance....... off the web.
This is the FW-190/A8-R7 1/32 scale resin up-grade
by Eagle Models.
Note you can us this up-grade together, of separately
.... to simulate any of the three mods.
This is what it look like on the a/c
Note the three side plates.
Mike
