My 1:35 Italeri M110 A2 Howitzer
That's some fine work,JJ! (y)
As a suggestion;use our own Modelers' Alliance Gallery.
People will more then likely reply on direct pictures rather then follow a link.
See how it's done with the M.A Gallery (Copper Mine Gallery): https://www.modelersalliance.com/how-to-use-our-gallery
Greetings,Ron.
Not bad, also gotta work on your photography. Watch your focus point, some of those shots the back ground is more clear than the subject. Might want to get a blank backdrop to photo against, though I'm guilty of taking shots at the work bench also..
Ron pointed you to the Gallery but we also have where you can attach imaged right to the post. Just reduce them to no more than 1028 width and you should be good.
