Tankbuilder
I meant to add to the list that Terry put together an entry to the effect of "Be advised of judging", last on the list. Only to avoid the confusion at the end of judging and to be aware that, despite all efforts and quality, things can be totally opposite from one show to the next.
Back on track - know the rules .... I have attended shows here that require references and judge by IPMS rules (sort of) and others that do the speed judging thing, by selecting one club member and one volunteer for each category.
Nothing much to say about the speed judging - avoid blatant mistakes (gaps, brush strokes, glue stains), everything should line up nicely (wheels on armour for example, and cars too), no seam lines.
No silvering on decals, correct alignment and so on.
Much is to be said about weathering vs. not weathering, OOB vs. modified and so on. However, I would ask the judges / organisers prior to attending if there are ANY amendments to the rules or any changes. To sum it all up:
- read the judging guidelines
- make sure your model(s) are in the correct category
- even if there is a perfect understanding of the rules, ASK if there had been any changes.
Hope this helps
Laurence
Add to that the hope that the judges aren't biased against what yoyr entry represents nor know it alls who dismiss a model out of hand because they've never heard of it tthe way you represented it despite evidence you have that it exited as your model represents.
Some judge absoluye totally ruin the contest experience and turn odd modellers from ever entering another contest.
Cheers from Peter
