Using salt for weathering
Hello
A couple of shot of how tu use salt for weathering. I normally use two or three different salt types, fine, medium and rough sea salt.
Different rust colors are paintet on using a sponge.
Water is applies with a brush and salt is sprinkled on to the wet surface and left to dry a couple of minutes
The fender is sprayed with the main color. I use Tamiya acrylics.
As soon as the paint is dry I genty remove the salt using a brush and running water.
Different Mig washes and oils is used to weather the fender.
and here the fender is placed on the base..y..
an another project where I used the salt technique for weathering
Author
Views
4,785
First release
Last update
