AndyFettes
For a seam that big on the outside Id use putty
...the ones running up and down are Frames or ribs, I'm not clear on that one.
Saul, what was the little box in between the stabilizers that got the armor?
Mike, the early type of machine gun pedestal suggests an E/F model.
So does this mean no NMF??
Bummer...ah well...the inside will be aluminumish I guess
Ok...so if I do the styrene sheet thingie...what is the template for?? Just to get an idea of the size?? If I glue this sheet over the outside, how would I hide the edge so it doesn't look like a sheet glued to it?? Maybe some strip styrene? My worry is one pics won't stayed glued and it'll peel up on me later. As far as rivets go...maybe a pounce wheel like Chuk uses??
when you say to warm the styrene...am I right in assuming that means placing it in some warm or hot water and not like leaving it next to my wood stove?
Are those rivets available in the 1/16 scale?
