I gave all mine away. Only have a few on hand. So inconsistent, you can get one color thin and spray then the next batch is all over the place. There's better paints to be had.I finally had to give up on the Vellajo paint
It's a shame as I'm heavily invested in Vallejo supply. But the difference is night and day. I can even leave the Tamiya in the cup, while I take the dogs out and return to spraying. Could never do that with the Vallejo. I'm not bashing a product just saying it just doesn't work for me. It's not just Vallejo as I tried the Sqaudron brand with worse results.I gave all mine away. Only have a few on hand. So inconsistent, you can get one color thin and spray then the next batch is all over the place. There's better paints to be had.
Yep. I admit I've never used Tamiya paint. Mainly because I could get Vallejo at Hobby Lobby, the only "hobby" store in our area, till Sqaudron opened their headquarters here recently. I just thought there was something wrong with my airbrush. Now I can lay down a pencil thin perfect line. I have total control of the paint. I kind of feel like an idiot.Vallejo is one of the best brush paints and the worst Air Brush paint IMHO. Have to use the right tool for the right job…
It can be made to spray, but you need their AB thinner and retarder and the mix has to be just right...Yep. I admit I've never used Tamiya paint. Mainly because I could get Vallejo at Hobby Lobby, the only "hobby" store in our area, till Sqaudron opened their headquarters here recently. I just thought there was something wrong with my airbrush. Now I can lay down a pencil thin perfect line. I have total control of the paint. I kind of feel like an idiot.
Yes. I use their thinner and retarder. I can get the darker colors to spray out okay, but even those can become a bit of a hassle. Airbrushing had become more of a chore than anything.It can be made to spray, but you need their AB thinner and retarder and the mix has to be just right...
I have found the same Tim....I used to do lots of airbrushing but over the last few years I have tended to brush paint and use pigments to steer away from the hassles of cleaning and clogging after every color, except when I spray Tamiya -never an issue then.Yes. I use their thinner and retarder. I can get the darker colors to spray out okay, but even those can become a bit of a hassle. Airbrushing had become more of a chore than anything.
I could get the job done with the Valleyo, but it was always a struggle. Sometimes I'd have to break down the brush a few times during a session. After using Tamiya for the first time on this build I'm just shocked at the difference their paint made. It's effortless. I was happy I wanted to take it outside and continue by airbrushing our houseI found Vallejo can tend to deposit along the inside of the airbrush canal to the tip. Thus the tip has to be removed and cleaned out to make things work right. I have found like Tim that I cannot just let the paint set in the airbrush for a bit and thus plan on spray, empty, clean. The clean is to use Lacquer Thinner which does break "V" down and get it out of the brush. I will use that to rinse and then add the next color if I am going to spray again. If I am done, the H & S airbrush breaks down quite easily with easy to handle parts. So I break it down a do a thorough clean so it is ready for the next time.
Have not picked up any of my Badger airbrushes in a couple of years.
It's mind boggling the difference the Tamiya makes.I have found the same Tim....I used to do lots of airbrushing but over the last few years I have tended to brush paint and use pigments to steer away from the hassles of cleaning and clogging after every color, except when I spray Tamiya -never an issue then.
Thanks for that info Ian. I was thinking that that's how they would've done it. I am purposely trying to make this tank field painted. Like leaving the inside of the idlers and sprockets dunklegrau as well as along the bottom of the hull sides. It's a bit difficult because it comes of looking like a poorly painted model. Even I can't go as far as to over spray the Gelb onto the tires though.The majority of German tank photos i have tend to show the crew overspraying everything if its in the field - works better as cammo in the field. too.
I'm using a Iwata hp-cs. Most of the time the pressure is at 20 psi. My old Thayer & Chandler quit on me several years ago. It had a .2 needle and was a Ferrari when spraying out lacquer thinned paint.I found the H & S airbrushes work SO MUCH BETTER than the Badger brushes I used in the past when using Vallejo. Even other paints spray better. I guess tonight I will do a photo comparison on the airbrushes to show the difference because it really does make a difference.
I saw an online hack where a guy made an adapter to shake model paint on his saws all...lol.I loved Valejo for hand brushing but hated it for airbrushing until a buddy told me to get a good paint shaker. Got one off of Amazon, put a steel ball bearing into the paint and let it go for about a minute. Mixed it up awesome and then tried airbrushing and voila, I use them still.
