jknaus
Administrator
You must resist the urge to build them Ian.I have an EASY 8 that keeps winking at me as well as a late model Stug3 or a panzer 4H all in 1/16........I must be strong.![]()
You should be safe, there isn't a M3 Lee kit, yet.I will not be tempted...
But there are some Shermans and there is a quad 50 on a half track, and Moon Puppy loves haff tracks, especially hen there is a ton of PE for itYou should be safe, there isn't a M3 Lee kit, yet.
RichB
YET................You should be safe, there isn't a M3 Lee kit, yet.
RichB
I just have too much other stuff to get finished , including some shelf queens.You must resist the urge to build them Ian.![]()
Who has the quad 50 on a half track?Who has the quad 50 But there are some Shermans and there is a quad 50 on a half track, and Moon Puppy loves haff tracks, especially hen there is a ton of PE for it![]()
Who says?Y'all aint' right!![]()
Give in to the dark side...I have an EASY 8 that keeps winking at me as well as a late model Stug3 or a panzer 4H all in 1/16........I must be strong.![]()
I saw Andy's videos and no, there isn't a mention of that. In the build video he has the inner wheels on with the outer ones off. I wonder if he glued the inner wheel on and just painted them attached? They would still roll because of the hub bearings.There is a slide piece in the Pak 40 that follows the barrel when it is elevated. There are 2 arms that mount to the back of the plate and the plate slides up and down between the 2 layers of the shield. The arms fit into holes on the sides of the frame under the gun and while they tended to stay, they would wiggle in and out so I did the heated blade mushroom to them as well.
Andy supposedly built test shots or full kits of these and no mention was made of problems with the wheels staying in place.
Actually the instructions show just the inner wheels on, until the tracks are built. Then it shows adding the outer wheels. So evidently what they are telling you to do is glue the inner wheels on the shaft, you know, without telling you. I don't know. I'm going to do it my way. It would bother me having those wheels glued on right now...haha.I guess I will figure it out when I get there.
You pulling the trigger?I think that will keep me busy in retirement.
