I will do that.Looking at your fine lines, you may want to back off on the PSI and reduce the distance between the surface and the needle. That should tighten up the "jaggies" along the edges of your spray lines. HTH.
Yes it is.So Tiny!
Thank you.Just spotted this, great job frank, well done![]()
