Well i finally got back to this if only to properly photograph it ........i will do a quick review of what I think of the model in the box.
A QUICK REVIEW - DAS WERK 1/72 U9 CLASS.
OK, here we go......at first glance, as I remove the bags from the well constructed and solid box, the overall quality of the DAS Werk kit is what really stands out. From the box art, to the thick cardboard of the box itself and even the re-sealable sprue bags (that seem to be the way of all the modern manufacturers now), this kit is '
right up there' for quality.
If you purchased a kit from the first production run, Das Werk provide a full book on the U series sub with lots of detail and ref pictures, which is  great because I didn't have any info on this sub. Actually, I didn't know ANYTHING about WW1 subs! You can see a picture of it on the left hand side of the hull sprue picture in the next photo - a perfect bonus and very smart of Das Werk.
THE PARTS
The kit has 4 large sprues and a decal sheet for 4 options from U9 - U12.
The first sprue is for the 2 hull parts, which are quite long at 80 cm but still shorter than the Mk7. For me, the hull shape is what makes this early sub pretty sexy, with the ultra blunt bow and flat ballast tank tops. The less streamlining of this early design makes it look even 'meaner'. The detail is very sharp and crisp and will come up great with paint and weathering.
See attached thumbnails for a better look.
The other 3 sprues make up the deck and smaller details as well as the Conning Tower. The C.Tower having the option of the canvas wrap or the bare frame for the comand platform, with them being interchangeable even after completion, which is a pretty cool detail and again very smart of Das Werk.
The last sprue has a number of interesting parts such as the main deck and a really nice stand with the label in Imperial German style script.
Finally, there is the Decal sheet that has plenty of options for the first 4 U class boats as well as an imperial flag.
So now we have looked at the kit , here are a few extras I purchased to go with it......
EXTRAS
1. I also purchased the masks from Das Werk to paint the anti -slip texture for the saddle tanks which should make that process easier.
 2.
2. I purchased the full PE set from RC Subs and as far as I know it is the only one available still.
I also intend to have a full scale badge with each build, as I did for my original early Mk7 in 2007, so I purchased a 'repro' WW1 Kreigsmarine sub badge from Ebay.
This came in full metal, which is great but I needed to grind off the pin and sand the rear flat to attach it to my base.
