garywintin
Member
Ok guys.. here's my entry for this campaign ...
I'm not really a master so bare with me along on the build. Thanks.
Looking good. Usually for that flimsy retaining piece I tack it in then glue is heavily so the gun isnt an issue. I usually also end up choosing the gun elevation and make it static. An alternative to the Tamiya putty for making the cast look would be Mr Surfacer. For that I would use Mr Surfacer 500. Reason I mention it is that it is cheaper in the long run than Tamiya putty and is very easy to use. And if can be cleaned of the brush with alcohol. It can also be "sanded" with alcohol and paper towel. This video might explain it a bit better. Video from Scale War Machines on You Tube.
http://www.youtube.com/watch?feature=player_embedded&v=g2nI8bogQ8A
Hope its of some use.
BTW I have never used acetate with this product and I am not sure I ever will.
