Dave to bad these don't come in 1/32 http://www.mikegrantdecals.com/SmokeRings.html
If you read further down they are available by special order but they are pricey and I just blew my modeling budget elsewhere![]()
. I'm leaning towards the poached egg scheme anyway!
Oh Dave, that is quit a stretch for a 1/72 guy. I don't think you are going to have a problem with the smoke rings seriously![]()
Will look cool I am sure.
If I were doing the smoke ring paint I would do a reverse cammo, spray the green first then use rolled blu tac to form the rings.
When in place hit the whole area with white primer, then spray the yellow.
I did the same method on my TA 154 build.
For your pilot, depending how much you can see in the pit when all together, maybe slice off some plastic on the insides of the rudder peddles where his legs touch them,
his legs should hide the area.
HTH
