Skinny_Mike
Hi guys –
I just found out that the Space Coast IPMS show is planned for early April. For some reason I was thinking its later in the year and finally looked this week only to discover that its sooner then I thought. I planned to have a few other projects finished in time, but they are just not going to make it. I needed to get something together.
The contest theme this year, probably very consistent across the board, is World War 1 and hey, we have a campaign too! Looking at the stash, I have a couple of WnW kits and a Takom Mk I female tank. No way I’m getting a WnW kit done in 2 months, but I think I have a shot with the tank. Weathering will be the challenge. With that in mind, the kit is down off the shelf and we are off to the races.
Here is the appropriate start up photo.
After about an hour's worth of effort we are through step 2.
Each hull plate is a separate piece held together with a butt joint along the edge. I was really worried about this step, but everything went together really well with no issues. I drilled out the end of the machine gun before I installed it in what I think is the driver’s location. I also installed it in a bit of an odd angle as I intend to display this tank on a base with a broken track and a few of the doors propped open, abandoned on the battlefield. It didn’t end up quite as I envisioned it, but its good enough.
I was concerned about this assembly not being very sturdy as I continue assembling parts so I decided to reinforce the seams from the inside using plastic stock. This really served to solidify the hull assembly.
That’s where I am as of right now. I’m going to let the hull fully cure before I move on. I’ll be working hard on this and another build I started a few weeks ago, over the next 8 weeks. Modeling on a clock, trying to achieve contest quality… What could possible go wrong? Wish me luck!
Mike
Mike
