Help! Need Accessories!
Iron Mike
Howdy folks! In trying to finish my gun truck for Charlie Don't Surf II, I need help locating some accessory items. I'm looking for 1/35 scale push broom and maybe a grain or coal shovel. Anybody know of a source for these? Thanks!! :drinks
It's #1 or G scale...found a shovel in this set...
http://www.hobbylinc.com/htm/psr/psr45208.htm
There is a broom and shovel...although you may have to modify the shovel a bit?
Doll house stuff? Hadn't considered that. Thanks Mike, that looks like the broom, but was looking for a shovel to scoop up the spent brass. I'll have to keep looking, maybe check out the doll house stuff too. (y)
I think a broom would be pretty easy to scratch. Shovel, a bit harder, but if you took a shovel of about the same width from a British kit you could scratch the handle.
I have a flat, square nosed shovel from a Tiger kit, but it looks so German! You're right about the broom, I was just sort of looking for a quick and easy fix!
Hi Mike,
You could try PlusModel http://www.plusmodel.cz/katalog_en.php
Not sure if they have brooms etc. but they have a lot of not so usual interesting stuff.
Cheers Erik
