1/700 Tamiya USS Saratoga CV-3
I would offer no criticsms, as this IS your Sara and your model fun, but I think you have the earlier, 1942 Rabaul raid Measure 21 paint scheme Rather than the post 1944 refit Measure 32/11a dazzle paint job. Her career as a dedicated night carrier was in the offing.
Either way, she looks very fine!
I did consider this for a while, but I wanted a scheme she saw combat in, even if it was for only two weeks. I'll probably do a dazzle scheme on another ship at some point, though. I've been considering doing two versions of the Enterprise, Midway and later in the war, and she did carry the dazzle scheme through 1944.
On the subject of the number problem, what I'm thinking now is printing out my own decals. Has anybody here tried that?
@Rhino Hey Chris!
Decals can be printed out. Laser printers printing will usually work quite well. Ink jet printing will need to be coated with something as the ink will do weird dissolve things with decal softeners.
@Rhino Hey Chris!
Ah, top tip about the ink jet, since that's what I have. Thanks.
I do it often. I cain't print white. I have success with inkjet decals on clear decal paper. DO NOT buy the Koala brand of clear decal paper. It's about as thick as your fingernail.
https://www.ebay.com/itm/174733780487?var=473913826728
This is the brand I have had the greatest success with in 1/350 and 1/700 scale. They also offer laser jet clear decal paper.
View attachment 186473 View attachment 186474
What do you coat the decals with before doing any setting solutions etc.
I've used future in the past... :blink
Aaaaand now I've gone cross-eyed.
But that triggers a vague memory of this technique, probably from when I got Finescale Modeller in the 80s. I think they airbrushed their decals in that one. Future is no longer available, but another acrylic floor wax should do the trick.
The weekend report:
I decided to try painting the flight deck lines. It took a bit of minor masking work (sarcasm, it took a good chunk of Saturday) but it worked out pretty well. I goofed a little by continuing the centerline stripe all the way to the fantail, where the aft "3" is supposed to go. That should be an easy fix, though. I really wish that I'd waited to attach the island structures until after I'd completed the flight deck because it made the masking even more of a pain. Lesson learned for the Enterprise.
As for the numbers themselves, it looks like printing them out will work out great, except for one hitch. A test on a spare flight deck shows it turns out too dark. I tried to fade it a little and anything other than pure black prints out as magenta. I don't use my printer very much so it's probably the print head.
The flightdeck markings are outstanding! Try using a shade of blue, for the numbers, maybe? I'll wager your already thought of this.
I was thinking dark gray, but it's no problem to try it a couple different ways. I've got a new printhead on order which should fix the magenta problem.
Grays on inkjets are usually done as colors and are mixed. Thing is, you now have a pattern which you could cut out of paper and could use as a mask pattern.
Make the mask, set it on the deck and use some weight around the edges. There is also some double sided photo tape that 3M makes that is just barely sticky that you could use to hold parts in place as needed. Then airbrush with low pressure from some distance and you can get the desired darkness. It isn't as hard as doing the lines striping that you just did.
BTW the lines striping are superb! EXCELLENT JOB!
I would have gone that route if I'd needed to, but I'm happy to say the new printhead did the trick. I'll coat the numbers tonight and let them dry until tomorrow. Probably the left one on the bow, right one on the fantail.
I'm bashing the 5" guns together from the 3D print and the kit parts. On the left is the 3D print. It's beautiful, but after more than an hour I was only able to get the barrel partially in on one mount and crushed a lot of the gun detail doing it. On the right is the almost cartoonish kit mount, and in the middle is the kit gun on the 3D mount. I think that's about as good as I'll be able to do.
Somehow I was more successful with the 20mm. That's three pieces: mount, gun, splinter shield. It also comes with sights and ammo drum, but oh man 😬.
This is looking great - I love it! :vgood:
I am a bit late with my suggestion on the numbers so it won't matter now. I often put the decals down and seal them then paint the color you want on top, using them as a kind of reverse mask/ painting guide.
Ok, I'm sold on homemade decals. Just knowing I can print more if I screw it up is a big comfort. The aft decal is a bit darker under the film, but maybe following clearcoats will fix that. I'll probably spot some aircraft back there anyways.
