kryptosdaddy
Its an experimental design, they mounted a what? 4 tom 88 on a tank chassis and made some doors with the idea of opening the doors and using them as a variable shield or deck when the gun was in use! The men that worked this contraption probably called it something endearing like 'finger crusher' cause you know opening and closing those doors was a white knuckled and wide eye experience. Especially knowing that someone may be thinking of shooting at you while you messed with those doors! Makes sence it could be done from inside the shield. Loving this build Tony- thanks again CR :dude
