Logistics, Base & Buildings, Updated Feb. 13, 2020
Logistics, Base & Buildings, Updated March 5, 2020
I agree, this is amazing work that the camera cannot do justice to. I have also seen this with my own eyes and it is beyond words to describe.
:notworthy :notworthy :notworthy :notworthy :notworthy :drinks
I never tire or fail to be amazed at this build...regardless of how often it pops up. Simply fantastic. :drinks
Thanks Chris!
It'll likely pop up a lot more sown the road. It still has quite a way to go before it's finished!
Bob
Dang Bob. Just WOW!!!
Thanks Bob!
:yipee I can't wait until you get this done, Poppy. I don't think anyone has any idea how unbelievably detailed, huge, and cool this thing is. I've seen it many times in real life and I see things I never noticed before every time. Can't wait to see people's reactions when this thing is finally unveiled in toto.
Thanks Sweetheart,
AS often as you've see this, it is probably boring to you! But thinks for being a good daughter anyway! :)
Pop
I have seen it several times as well. Each time there is something I missed before in addition to whatever Bob has added in the meantime. Now I am getting some idea of what is in store for the train station. It's nice still in that I can run the camera down into the middle of all that work for unique photos. I can hardly wait to see it this next time.
It is really looking great Bob! The photos just don't do it justice..
Thanks Paul!
Funny, after all that work on the front wall, and now nobody will even notice it! It gets lost in the overall diorama!
Looking forward to your next visit!
Bob
Simply amazing :notworthy :notworthy :notworthy ...
Luiz.
Can't put that into words :notworthy :notworthy :notworthy
Laurence
Thanks a bunch Buddy!
Bob
Looking great! The dio has come a long way from when I first saw it.
(y) :notworthy
Yeah, and that was also a long time ago! You gotta come visit! We're not that far away anymore!
I was gonna count your ribbons but I got tired and gave up! :yipee
Bob
Hey Mark!
Thanks for the kind words! I've done quite a bit since you were here!
Bob
Words just escape me Bob-- I am just pleased I get to see the in-progress shots...must've have been what it was like to look over da Vinci's shoulder while he was working. You are truly a master!
B) Fantastic Bob. the detail will make this a piece to be appreciated for years after you have completed it!
I love the shot of the train from the front under the damaged metal framing. (y) (y)
If you need some help with that photoshop stuff in the future just let me know. ;)
Ian.
Hey Mark!
Bob
Indeed! I've been following this very closely and it's such a thrill watching it develop further from what I saw.
Thanks Mike!
I appreciate your nice words, but I'm afraid Da Vinci and I aren't even in the same league!
But thank you anyway!
Bob
Ian.
Thank you Ian, Really nice compliments coming from you!
That was my favorite shot as well, but the lighting disappointed me. Gave it a reddish cast that isn't really there.
I may take you ip on the photoshop thing!
Bob
Hey Mark!
Bob
Thanks again Mark!
Bob
Holy moly those windows look amazing :mpup
Thanks Dave!
They damned sure should! Three days worth of tedious work and a lot more to do! :bang head
Bob
I have been promising photos illustrating the finished train station for a few weeks. My problem is always all those tiny details and things that look finished but are not quite. The major hold up on this one was thousands of tiny windows that had to be filled with glass. Not all, but most of them.
I placed the train station on the diorama where it will go and then put the locomotive and rail gun in place and part of the canopy, (Train Shed), in place, so people can see where I am going with this. I only have a tiny few hunks of burned, bent and broken steel trusses, girders and I-beams so far. There will be many, many more. None of those or the larger part of the canopy towards the right end of the diorama have been weathered. They are only base coated. Neither has the rail gun. It has yet to be weathered or detailed.
I'll begin this with the reason for a lot of the delay. Those damned windows! I'm sure some will look at this and wonder why I didn't just use sheet plastic to fill them in. The Micro-slip glass would have taken me another 10 years to use that, cutting each one with the home glass cutter I have posted in other threads here. Sheet plastic could have worked where all the tiny frames were full and intact. However, although the windows in the train station will have far more intact glass that the shed when completed, it would have been a nightmare to cut out random quarter inch by quarter inch windows blown out of the frames by explosive concussion. Even then, you can view both sides of the windows in this diorama and there would have been frames only on one side using sheet plastic.
In the past, I have used Elmer's white glue to make windows like this in the past. It does work. However, I had three bottles of a product Micro Kristal Klear. So, I used that.
I use a round toothpick, (A flat one takes longer), dip it into the glue and then run the toothpick around all four sides of the frame until it fills. Not as easy as it sounds!
Then, when filled, gradually pull the toothpick out at one of the corners very carefully and slowly. Otherwise it will open up and you have to start all over again. I did that a lot!
Because of the height of the train station, I had to stand up while doing these. There are hundreds and hundreds on the train station alone.
It was a long, painstaking process over a three day period. When dry, close up, they resemble glass blocks. From a distance they look like glass.
The windows from the rear of the roof.
The skylights on the ceiling of the hall being filled.
Finally finished. They begin to dry and become clear almost immediately. It takes maybe 30 minutes to cure.
Here you can see both the rear windows as well as the skylights.
Once cured, they look like windows.
Here I have put the train and the unweathered canopy in place on the other end of the diorama.
Here you can see some of the steel girders, I-beams and window frames in place. I still have lot more to do to them.
And her, the canopy that connects to the trim station.
The rear of the roof. Still has some more weathering. That will come when I finish the canopy altogether.
Here the badly damaged canopy connects to the right hand wall of the train station. A lot of the photos have a red cast. It has something to do with the lighting in that room. To move it elsewhere would require another three people. When the diorama is finished, I will have it taken outside to photograph.
The Locomotive, rail gun under the canopy. BTW, all the 53 vehicles in this diorama are just sitting here and there on the base, not where they will eventually go! Also, I still have to add all the light fixtures and signs, signals, etc., to the underside of the canopy.
Here is photo I photoshopped to remove the background. I am no expert on Photoshop for sure. A person trained in it could do a much better job. When all this is published in a book, there will be a lot of photoshopping to erase the background walls and other things.The area I did is where the black is.
The Train station interior.
Various shots of the tracks.
I have always like the woe's eye view photos. They are dramatic and look more real.When the RR gun is detailed, weathered and damaged from the Allied bombing raids, both with explosives and incendiary bombs.
Another view.
From the right.
A better view of the station interior.
Again, the yet to be weathered cnp[y.
Ditto.
Hope you guys enjoyed this very long post.
Thanks for stopping by!
Bob Letterman
See, I said I'd be back. Bumping to a new page. :good:
Just bumping this for every ones enjoyment
