Hi all,
A new desert-dio in progress.
The first vehicle, a British radio truck, is already described in the "Armoured Fury" section(QLR on CWT).
Here just a memory, meanwhile the doors are mounted.
Second vehicle is a M3 Grant, in fact a M3 Lee with a new designed turret.
As this is the Academy kit, some interior pics.
I didn't do too much effort here, you cant see very much once closed.
And a walk-around.
Some dust, sand and pigments will be added later on the dio-ground.
Last time I promised a Step-by-Step how I make desert groundwork.
Here is the start.
Piece of wood, covered with foam. This can be the cheapest kind, it will be covered.
But mandatory, otherwise the wet plaster/paint will deform the wood.
Next build up some heights. Any material will do, but I prefer hollow shapes because of the weight.
Next will be the plaster, see you then.
Thanks for passing by,
Willem
And a walk-around.
Here is the start.
Willem
