Bagge
Add On Parts French house corner
Here is an in box review of a new kit from the Belgium company Add On Parts.
The subject is a French house corner. Item Nr: 350076
/gallery/albums/userpics/11098/P1140766.JPG
Scale is 1/35
Dimensions of the house:
Height: 25cm
Base: 11x12cm
Retail Price Around 30 Euro.
The kit comes well packaged in a box with the ceramic parts packed in bubblewrap.
/gallery/albums/userpics/11098/P1140768.JPG
The kit contains 2 ceramic pieces for the house walls and 2 pipes for on top of the chimney, And then there is 3 resin parts, The roof, with nice sheet metal surface and 2 shutters for the windows.
The parts fits good and there should be no problem for assembling.
/gallery/albums/userpics/11098/P1140773.JPG
I found some small bubbles in the ceramic castings, in the area around one of the windows, but that’s an easy fix, either fill with some spackel or make them look like bulletholes
Also included is a ceramic glue that must be mixed with water for gluing the ceramic parts.
/gallery/albums/userpics/11098/P1140774.JPG
/gallery/albums/userpics/11098/P1140775.JPG
It's here on the trim on the top window you can see some tiny bubbles.
/gallery/albums/userpics/11098/P1140776.JPG
/gallery/albums/userpics/11098/P1140777.JPG
Chimney pipes.
/gallery/albums/userpics/11098/P1140778.JPG
The quality of the castings are very high, and i just saw the above mentioned bubbles, other than that it is a crisp casting, both ceramic and resin (the resin just need some sanding on the backside as all resin castings), and the level of detail is also very high.
The resin parts.
/gallery/albums/userpics/11098/P1140782.JPG
/gallery/albums/userpics/11098/P1140769.JPG
/gallery/albums/userpics/11098/P1140783.JPG
All the parts together.
/gallery/albums/userpics/11098/P1140779.JPG
/gallery/albums/userpics/11098/P1140781.JPG
It's a beautiful kit, and will make a nice addition to a diorama.
Here is a link to retailers.
www.addonparts.com/dealers.php?osCsid=2a...f95c57a1ba1d14ccd841
Thanks to Nico and Matthias at Add On parts for supplying the review sample.
Author
Bagge
Views
2,428
First release
Last update
