Thanks Saul. I found some very nice road wheel files and have printed them out. They look crisper and have the rivet detail that has to be added on the Atsuka kit. I will attempt to continue with the bogies although now I know of another source I will see if I can find them. Thanks for the info on the cupolas. I guess I do not need to worry about getting them as I am doing a Sherman Mk V. I got the replacement gun cradle for my Stug and have been building it when I have actually made it into the basement. I also found some upgrade files for an Italian M13/40 which i have printed out including track. There is also a conversion for the M13/40 to make a command vehicle. Now I just need to find which track my Sherman used and I may have a source for files to print out Sherman track instead of using the rubber band track. We'll see how this weekend goes. Again thanks for the info Saul.@jknaus, replacement roadwheels were made by TMD specifically for the Tasca/Atsuka (& Tamiya rebox) kits. Complete bogies (and their roadwheels) from Formations Models. I know the former ceased trading but not sure of the second.
The only 'British' cupola is the Mk II (seen on Fireflies as well). These were offered by Formations Models, Resicast, and one could adapt it from the included cupola in AFV Club's Churchill kit. Click image for my discussion:
While your decal is for Atlas, here is ACE where you can clearly see the track:Now I just need to find which track my Sherman used and I may have a source for files to print out Sherman track instead of using the rubber band track.
Yeah, I think thats T-54E track although I'm nbot really sure. It is supposed to be the most common. II can get a file for that on Cults3D.While your decal is for Atlas, here is ACE where you can clearly see the track:
The name changed to T54E2 so look for that. As for me, I went Bronco:Thanks Saul. Unfortunately cant find that design so will go with the Type 54E1 as it is close and it was common. If I find the correct ones I can change it later...
I've never even seen the Bronco tracks. HmmThe name changed to T54E2 so look for that. As for me, I went Bronco:
AK repackages R-Models' metal track sets. I wasn't impressed with the photos.
