Photography Question...
You know how at noon at the beach you can see every detail of that bikini from 100 yards away, but will walk into lawn furniture at dusk? Our eyes are designed to pick out detail and color in daylight, not at night. Dog's eyes don't detect color well but see great at night. The camera is just a simple version of our eye.
Photography is all about light. The more light, the better for detail and focus. Light adds depth of field (width of area in focus), so more of your model will be clear. When I say more light, I mean intensity of it, not quantity. Nzgunnie nailed it in terms of what you need on a static subject: three lights at most, but one well aimed with some reflection will work well. Ideally, you use one main (key) light, one fill and a background. The fill is less insense than te key and usually comes in from the other direction, meant to hit any dark spots on the subject. The third, if you want, is the least intense and is aimed at the background just to cut shadows cast by the first two.
Get as much light on it as you can, even more so if it's a cheap camera. Shoot outside on a bright day if you can, but not in direct sunlight, that's as bad as using a flash. Just set up near the house (provided it's a light color) to get reflective bounce. Remember the old photos of people taning with the trifold aluminum screen under their neck. Use that to do the same on a model. On exterior movie shoots, they use huge reflective panels to aim the ambient light whereever they want.
As mentioned, tripods are great, but...in low or medium light, just the action of depressing the trigger is enough movement to knock the pic out of focus. Set the selfie timer.
This pic of my Iwata nozzle for the review is a good example of depth of field/light. Look at what's in focus, just the tip and the very front of the threads, the rest of the housing, immediately in front and behind the nozzle is blurry. The depth of field is about a quarter of an inch. That's with a hundred watt bulb about three inches away from it, coming from above right. It wasn't shot with a tripod, but the camera is propped on a box and there's enough bright hot light, the shutter speed was very fast. The faster the shutter speed, the less chance of going out of focus from movement.
Another point is background. If you have a simple sheet of paper (you can get 2 X 3 sheets of cheap colored paper or plain newsprint), the camera has nowhere to focus but on the model. Us too, since our eye is always looking for detail, at least the way my eye looks, I see plane, box background, what's on the bench, what's cooking on the stove. etc. If there's a solid color background, I only look at the plane. :D
Ed...
I looked your camera manual up online- there is a self timer feature...p. 36 of your manual...it's basically the up arrow on the four way button on the back of your camera...
I went over the above photo with a highlight. The green area is the only spot in the photo in focus. You know how small AB nozzles are, this gives you an idea how small of an area a camera can concentrate on. Thr further away from the subject and the more light increases the depth of field (in basic terms, in actuality it's the lens and aperture, but you don't have a way of playing around too much with a point and shoot), but you get the idea of the problem. If the camera focuses of the antenna mast in low light, the fuse, wing, or anything else will be blurry.
Thanks fellas. Some food fer thot & I appreciate it.
Mike, I gess I gotta find my manual online & read up... :good:
You don't have an LCD screen on the back of the camera that has an aiming thingy?
I so love technical jargon :rotf
For your info, I never use a tripod and seldom use a flash . A beauty of digital photo's is that the camera doesmost of the light sensitivity adjustment on it's own.
On the other hand I move my desk top light all over the place to get descent lighting but it's only one of those circular neon light ( cool white ) Nothing special .
I use the tripod since I have a bad case of the shakes... I need to move another light over to my bench...
I thought about that possibility but as I was typing that though seems to have gotten derailed ( sorry ) and did not make it in my comments :(
No problem Christian, MP was kind enuff to send the tripod to help me with taking better pics :)
Ed, Walmart sells the old style clamp on work light. A couple of these with daylight compact fluorescent bulbs will help your lighting tremendously.
Work light
Hmmmm, have a couple of those that I used for remodeling purposes but they do put out a lot of heat.
This item is very similar to what I use ( I salvaged mine from a trashcan ) .
Anyhow, found this on Ebay for $ 40:00....free shipping . I love mine and the fluorescent light throws off minimal heat.
Just food for thoughts if you can manage it. Don't even have to worry about it falling over.
Work light
I know I had one of them awhile back. Might be in storage :unsure: I do have a similar one like Christian posted that I'll attach tot he bench in a bit & will post a photo after the race..
Thanks fellas :drinks
A great cheap light for taking photos is a set of those halogens work lamps. They throw off brilliant light that you can just bounce off walls or poster board and aim however you want.
If I'm taking serious photos or doing animation that's what I use. I place a material called Tuffspun over them, it's fiberglass netting that takes heat and is sold in increments of f-stops.
I'm not suggesting you go all in and buy a bunch of gear, just putting that out there in case you have them in your garage or something. They're the caged, tough but cheap lamps from Home Depot, etc. that act like artificial suns. Aim that at the walls next to your model and it'll be like you're outside on a bright day.
I don't have a heat problem with CFL bulbs. I only use them for photo taking.
The manual is available here. http://www.manualslib.com/manual/145721/Samsung-Digimax-300.html#manual
It looks like you do not have an auto focus on that camera, so I would suggest using the self timer feature (page 36)
It may also be beneficial to check out pages 41 and 42 to make sure the settings are where you want them. You don't need a lot of fancy gear to take clear photos, cropping a larger clear image results in a clear close up. As Ausf said, you need a plain background for good photos, desk clutter detracts from the shot and confuses the camera. Good lighting helps, but you can change the exposure on a photo using photo software if you need to.
Bottom line, digital photos don't cost anything except time, so take plenty until you get the shot you want. Practice, practice, practice, just like modeling.
I found the manual & downloaded it. I've changed some settings (mainly the image size & quality) will take some pics soon as I can. Been busy here. Had my Physical Terrorist session yesterday morning & then spent the rest of the day runnin' mom around doing first of the month stuff :gogo
Thanks Mike, and all, y'all gave me food for thot on this. I'll try to put it top good use :good:
So this is great news I can finally see what your building ...Maybe even change me opinion on how good you are ... :ro: :dude
Thanks Gerry! At least ya gotta admit, my photos have improved since MP sent me that tripod :D :drinks
Not so sure the tripod done it .... I do have the shakes some so I set My Camera on Anti-shake anti-rattle But I think your photos are improving because you read the Destructions ... :good: :facepalm (y)
P.S. Looking very good there Buddy ... :woohoo: (y) :woohoo:
Let Me Peruse it a little :captain :skipper :captain .... yep not bad ... (y)
The tripod does help Gerry...
You remember this pic from waay back Same camera. No tripod
Well, here's a few more pics I just took a few mins ago...
And the work Bench with my lamp/magnifier
Does it put out enuff light? :hmmm :drinks
