Welcome, Guest
TOPIC: Micro Mark Jewelers Miter Jig
Micro Mark Jewelers Miter Jig 16 Mar 2016 06:51 #1
While browsing the tool section at Micro Mark last week, I came across the #86485 Jewelers Miter Jig and thought it would be a good addition to my arsenal. The jig is well made, it is hardened steel to allow the use of files to finish up the workpiece. There is a stop bar that can be adjusted for repetitive cuts, it is easy to adjust and removes when not in use. The grooves accommodate either square or round stock easily.
I cut a lot of aluminum tubing building cars and couldn't wait to try it out. A piece of K&S aluminum chucked into the vise.
If you plan to make more than one piece, here is the stop bar installed.
Read more...
IPMS Plastic Surgeon (satellite member)
AMPS member
Resident Curmudgeon
Last Edit: 17 Mar 2016 20:15 by Iron Mike. Reason: typo
Micro Mart Jewelers Miter Jig 16 Mar 2016 06:53 #2
Thanks for the look Mike :thumbsup
Hank Williams Jr.
Micro Mart Jewelers Miter Jig 16 Mar 2016 07:14 #3
I like It ... Thanks Mike ... :thumbsup :drinks
"Peace is that brief glorious moment in history when everybody stands around reloading" - Thomas Jefferson
Micro Mart Jewelers Miter Jig 18 Mar 2016 09:02 #4
Thanks guys. I didn't mention that there's a function for flat stock as well as,one for cutting 90 degrees. Happy modeling! :drinks
AMPS member
Resident Curmudgeon
Micro Mark Jewelers Miter Jig 18 Mar 2016 10:30 #5
Kewl man! :dude
  • iambrb
  • iambrb
  • OFFLINE
  • Division Commander
    Division Commander
Micro Mark Jewelers Miter Jig 20 Mar 2016 10:15 #6
Must have for scratch builders!
Thanks Mike!
Gr,Ron.
  • reconron
  • reconron
  • OFFLINE
  • Moderator
    Moderator
Time to create page: 0.190 seconds
