Welcome, Guest
  • Page:
  • 1
  • 2
TOPIC: Modeling for Competition:Basic Contruction
Modeling for Competition:Basic Contruction 14 Aug 2015 19:05 #1
MODELING FOR COMPETITION
BASIC CONSTRUCTION
Ok here is where the rubber hits the road! We have decided to get serious. We are getting a handle on competition rules. The kit has been selected. Research of the subject is underway. Now it’s time to start putting the things we are learning into practice.
Competition rules can be a club to beat us up with or they can be a tool for success. Let’s use them as a tool shall we. I look at the IPMS rules as check list of things that need to be done or considered. So let’s look at them again and see where we need to start.
Aircraft
Basic Construction
1. Flash, mold seams, sinks marks, copyright marks, ejector-pin marks, and similar molding flaws eliminated.
2. Seams filled if not present on the actual aircraft.
3. Contour errors corrected.
4. Any detailing removed while correcting errors, filling seams, etc. restored to a level consistent with the rest of the model.
5. Alignment:
A. Wings/tailplanes: same dihedral or anhedral on both sides.
B. Plan view: wings and stabilizers aligned correctly with, and identically on both sides of, centerline.
C. Multiple fins/rudders: fin-to-stabilizer angles correct; aligned with each other in front and side views where appropriate.
D. Engine nacelles/cowlings: lined up correctly in front, side, and plan views.
E. Landing gear: components properly aligned with airframe and with each other in front, side, and plan views.
F. Ordnance items (bombs, rockets, pylons, etc.) aligned correctly with aircraft and with each other.
6. Canopies and other clear areas:
A. Clear and free of crazing caused by adhesives or finishing coats.
B. Gaps between windscreen, canopy, or other clear parts eliminated where applicable.
C. All clear areas scratch-, blemish-, and paint-free.
7. Decals must look painted on if depicting painted markings (conforming to surface contours, no silvering or bubbling, no decal film apparent).
Armor/Military Vehicles
Basic Construction
1. Flash, sink marks, mold marks, ejector-pin marks, provisions for motorization eliminated.
2. Seams filled where applicable, especially on cylindrical parts such as gun barrels, wheels, and auxiliary equipment.
4. Gaps between upper and lower hulls blanked off to prevent a “see-through” effect.
5. Gap/overlap at point where track ends join eliminated.
6. Machine guns, main guns, exhausts, vents, etc. drilled out/opened up.
7. Cylindrical cross-section of gun barrels maintained.
8. Track pattern (cleats) facing in the proper direction on both sides of vehicle.
9. Alignment:
A. Road wheels on tracked vehicles (along with idler, drive, and return rollers, if any) at the same distance from the lower chassis centerline.
B. Road wheels sitting flush on the track.
C. Tracks vertical (not leaning in or out when viewed from the front or back of the vehicle) and parallel (not toed in or out when viewed from top of vehicle).
D. All wheels/tracks sitting firmly on the ground.
E. Vehicle components square and aligned.
F. Gun(s) (on most turreted vehicles) parallel to turret centerline when viewed from above.
G. Items positioned symmetrically on actual vehicle (e.g., headlights and guards, fenders, mud flaps, etc.) positioned symmetrically on model, unless represented as damaged.
Automotive
Basic Construction
1. Flash, sink marks, mold marks, ejector-pin marks, and similar molding flaws eliminated.
2. Seams filled if not found on the actual vehicle. (This is especially important on the car’s body. Rubberized kit tires usually also have a mold seam that must be removed.)
4. Gaps between body and chassis eliminated as applicable.
5. Detailing removed while accomplishing the above steps restored to a level consistent with the rest of the model.
6. Alignment:
A. Where applicable, external items (e.g., mirrors, exhaust pipes) aligned symmetrically.
B. Internal items (e.g., seats, some engine/drive components) aligned properly.
C. Wheels: All wheels touching the ground and aligned properly when viewed from front or rear of the vehicle. If turned, front wheels should be aligned in the same direction.
7. Windshields and other clear areas:
B. Gaps between windshield, windows, or other clear parts eliminated where applicable.
As you can see the “rules” look more like a check list. On aircraft the first four items, armor the first eight, and automotive the first five deal with the preparation of the parts. While the other items really deal with assembly and most of the items listed are self-explanatory except for maybe item one. Now let’s take a moment and talk about item one “Flash, mold seams, sinks marks, copyright marks, ejector-pin marks, and similar molding flaws”.
•Excess plastic at parting line or mating surface of the mold
•Normally very thin and flat protrusion of plastic along an edge of a part
Sink marks
•Surface depression caused by non-uniform material solidification and shrinkage.
•Most often noted at interface between differing wall thicknesses.
Mold seams
•These are created when the two halves of the injection mold come together.
Ejection pin marks
•A rod, pin or sleeve which pushes a molding off of a core or out of a cavity of a mold.
•The pin will leave a mark or depression in the part.
Gate
•The Gate is the end of the runner. It is the entrance to the cavity.
Ok now that you have had a crash course in plastic injection molding I hope you will have a better understanding of the areas that may need your attention while preparing your kit parts for assembly.
Basic Construction Tools
1. Knife or scalpel
2. Sprue cutter
3. Sanding sticks
4. Cement/Glue
The tools for modeling are many and varied. Each modeler has their own way of modeling, but I think we can agree that these 4 items are basic to model building. As we go along with the building process we will get to see how each modeler in our class uses their tools to overcome the problems with the kits they have chosen. Hopefully we will learn some new things and master some others.
Basic Construction Steps
1. Study the instructions: instructions are like a roadmap so look the instructions over for anything special that needs to be done.
2. Do the steps in order: The manufacturer has arranged the steps for a reason. If you do things out of order you may regret it later.
3. Dry fit the parts: Check the fit of parts and assemblies before any cement is applied. Glue is not very forgiving.
4. Use a minimal amount of glue: Glue marks are first thing judges look for at a contest. Use just enough glue to get the job done.
5. Take your time: Modeling is not sprint, but rather endurance test. Don’t get in a hurry you might tear something up.
Ok I think we have enough to get started. So open those boxes and start cutting plastic. As usual I want to see pictures and explanations about what you are doing. This will help everyone learn something new. The next installment will be “Details”. From now on we will keep working as the next topics are closely related. Well let’s go!
Read more...
  • OFFLINE
  • Master at Arms
"We herd sheep, we drive cattle, we lead people. Lead me, follow me, or get out of my way."
General George Patton
The following user(s) said Thank You: Arturius
Modeling for Competition:Basic Contruction 15 Aug 2015 09:37 #2
I think we just got our Greenlight! Go man go!
Great article Terry. Think you got all bases covered, folks first starting off in the hobby will benefit from this as well as we who have been hacking at it for so long.
:thumbsup
Hank Williams Jr.
Modeling for Competition:Basic Contruction 15 Aug 2015 10:51 #3
Sweet!
My 1/72 F4U 1-D came in from Japan on Thursday, so I'm ready. :bgrin
Now, here's my question, the kit has a bunch of inaccuracies according to references and besides the fixes, I plan on going overboard with the landing/formation/ID lights, etc as well as converting it into folded wings. A lot of the detail has to be done before basic construction, should I start now or wait?
  • ausf
  • ausf
  • OFFLINE
  • Division Commander
    Division Commander
What, me worry?
Modeling for Competition:Basic Contruction 15 Aug 2015 11:15 #4
GO GO GO!!
Attack attack attack... :soldier :soldier :soldier
Hank Williams Jr.
Last Edit: 15 Aug 2015 11:16 by moon puppy.
Modeling for Competition:Basic Contruction 15 Aug 2015 12:45 #5
Again, well done MrT!
:coolio
"Damn they made me put out the candle"
Modeling for Competition:Basic Contruction 15 Aug 2015 13:37 #6
Great Article Terry!
Wish I had more time to follow along with a build of my own...
//Mats
  • Bagge
  • Bagge
  • OFFLINE
  • Campaign Advisor
    Campaign Advisor
Modeling for Competition:Basic Contruction 15 Aug 2015 19:44 #7
These are excellent details on how to get started. I like it. However, I would like to suggest some possible addendums to these instructions:
a) Sometimes, you do need to skip ahead or do a certain assembly process out of the sequence that the instructions give. Reading and studying the instructions helps to see this and prepare for that possibility should it occur.
b) I think we should add some basic putty/filler to the list of tools that should be used, given the need to do so on many different kits. Achieving the basics does include making sure all gaps and seams are sealed properly.
Just my two cents. Maybe you are starting a bit more basic course than I interpreted; if so, disregard my suggestions as being for a more intermediate course.
Okay, now I need to get my model together and get started on it.
Modeling for Competition:Basic Contruction 15 Aug 2015 22:18 #8
Point a) I think that's something that comes from experience Mark. Also depends on the instructions of the kit, we all have seen instructions that were merely suggestions then others you better follow to the letter the sequence of events.
Hank Williams Jr.
The following user(s) said Thank You: Duke Maddog
Modeling for Competition:Basic Contruction 15 Aug 2015 22:23 #9
There is nothing basic about putty and filler, however I'm sure we'll learn all about it during our build. To tell someone starting out to skip around is a recipe for modeling disaster.
B)
  • OFFLINE
  • Master at Arms
Modeling for Competition:Basic Contruction 16 Aug 2015 09:34 #10
With all of the online resources available today I consider part of the research phase is looking for other build logs for the kit you are planning on building. While everyone has their own level of pain quite often you find for a certain kit that everyone finds the same pit fall whether it be a fit issue or an assembly sequence that would work better than what the instructions may call for. In that case some variation from the instructions may be helpful but as a general rule what Terry said is the best advice if you have no feedback to the contrary.
  • Old Dog
  • Old Dog
  • OFFLINE
  • Group Captain
    Group Captain
Modeling for Competition:Basic Contruction 17 Aug 2015 01:37 #11
Very good points gentlemen. Thank you.
Modeling for Competition:Basic Contruction 18 Aug 2015 09:36 #12
Ok .... Green, ... Green, ... Green !!! ... My Book on the Dauntless will be Here this week ... I finally was able to order it ... but I have lots of Photos that Mike & other have sent Me ... the little lock thingie is gonna be hard to create ... but must be done ... Also just paid for my Eduard PE additions they're coming from Jolly 'ol I believe ... So I can't wait to get started ... Lots of Photos and lots of other life things in the way ... :woohoo:
Thanks for the write up Mr. T ... excellent as always ... Now Ya'll don't get side-tracked ... stay on the Main Line ... Let's build some Models ... For Competition I'm sure Mr. T will expect Mine @ Eagle Quest next Year ...
"Peace is that brief glorious moment in history when everybody stands around reloading" - Thomas Jefferson
  • Page:
  • 1
  • 2
Time to create page: 0.208 seconds
