Welcome, Guest
  • Page:
  • 1
  • 2
TOPIC: MODELING FOR COMPETITION: RESEARCH
MODELING FOR COMPETITION: RESEARCH 29 Jul 2015 19:48 #1
RESEARCH
Why do any research at all because models are always accurate right? Sure they are and hey by the way I have a bridge to sell ya. The reality is that there are no completely accurate kits out there. Tooling costs, molding constraints, and poor manufacturer research all contribute to inaccurate models. Having worked as plastics part designer for 15 years I can tell you some things just can’t be done. The process is getting better, but still challenges remain. A lot of the kits we build especially from the older manufacturers are using tooling that is pushing 40 years or more. They may add some new parts to spruce up the kit and release it again, but for the most part that Monogram B-17 is still the same mold they were using in the 1970’s. Manufacturers do this to save cost. Fifteen years ago a four cavity tool could cost $100,000+. A lot has happened in that time but as you can attest kit prices are not going down. It costs a lot of money to bring you your one off paper panzer. The point is unless it says “all new tooling” you can expect some of the parts in the box have been run before and if those parts were wrong the first time they are probably still wrong. The question is how do you know they’re wrong? Answer research!
One of the first things I do after selecting the kit is to find out as much about the subject as possibly. I try to break down the research process by the different steps in the kit instructions. So if it is aircraft I will look for information about the cockpit or engine whichever is step one. For me the research process may be on going all through the build depending how much I already know about it.
Pictures….pictures……pictures! I want pictures of the real thing. Over the years I have accumulated pretty large reference library, but there are still plenty of holes in it. So I turn to the internet. There is information about just about anything you might be doing. Don’t be afraid to be specific with your searches. I put in “1974 diamond reo rear air brakes” and came across several pictures I could use. There are all kinds of “walk arounds” on the net. There are plenty websites dedicated to just that Prime Portal be one. So spend some time surfing.
Read the history! I read up on the subject because it’s not just about how it’s made for me, rather how was it used, how did it work. While working on DH2 (still under construction) I noticed that there was just one return spring on the rudder controls. I thought that was odd until I read that because of the spinning engine the plane was difficult to control without it. So read there may be a reason why Sherman crews tied logs to the side of their tanks.
Start building your own library! There are all kinds of books, cd’s, dvds, etc….etc.….out there and some are very expensive, but (not to plug Squadron) the Squadron “in action” books and now the “walk arounds” will give you pictures and history on most military subjects for not a lot of money. For cars I use good old plain “hot rod” magazines. They are a great source for pictures and often show car broke down to the frame.
Study the real thing! I am always looking for reference material. I carry a camera and most of you have them as part of you phones. When you see something you are working on take a picture of it (with permission). I nearly wrecked the car while looking at the details of semi next to me (don’t do that). Be a reference collector. Sherman18 is particularly good at that and has posted many many pictures on the forum.
From a contest standpoint IPMS is rather vague on research, but it is mentioned over and over particularly where paint and marking s of concerned “models with unusual colors should be supported by confirming documentation”. I would assume that any other unusual aspect of your model should be documented as well and that documentation be provided with the entry. In the IPMS rules there is an extensive section on accuracy that I think all modelers should keep in mind and in perspective when competing.
“Judges take lots of hits from modelers who know some minute aspect of a prototype and mistakenly believe that judges must also have that much detailed knowledge and more. It’s simply not possible for all IPMS judges to match, model for model, the expertise developed by our disparate and incredibly knowledgeable membership. Don’t assume that the judges know all the details you know. Help them and help yourself by putting a little time into the entry sheet or any other display material you put out with your model. Judges do read that stuff, and it could make the difference for you.”
AMPS rules provide .5 of a point if you do research and provide it with the entry. The rules are specific.
“Optional Research Bonus (0.5 point)
There is an additional bonus of 0.5 points for Research, which may be awarded by the judging team. To obtain this 0.5 point bonus, the modeler must document to the judging team the link between the research they performed and the finished model. This documentation need not be extensive (two pages or less), but must address, at a minimum, the following areas:
Description of Research: The modeler should provide a short description of the research they performed to build the model. The modeler must describe in his presentation how or why his model looks, either directly or indirectly, like the vehicles mentioned in the research. The model could look like the research by applying some of the following: similar paint schemes, markings, weathering, stowage, field modifications, or by using technical drawings to create the model displayed. The modeler can use pictures as part of this description.
Research References: The modeler should list the research references they used while building the model.
If the modeler provides a brag book or other description of how they constructed the model, without providing a description of their research in the format above, they will not be awarded the 0.5 point bonus. The link between the research and the model is established by replication and presentation of one, all or some of the following on the model being judged: paint schemes, markings, stowage, weathering, historical context, descriptions of similar vehicles or the use of technical drawings to create the model – based upon the research documentation provided.
Examples of acceptable research format are attached at Appendices 1 thru 3
Judges Note: Based on the information provided by the modeler, the judging team should ask the following questions.
1. Does the model, either directly or indirectly, match or look like the description(s), text explanations and/or pictures provided in the research? (paint schemes, markings, stowage, weathering, historical context, descriptions of similar vehicles or the use of technical drawings).
2. Is the research documentation format requirements met?
If the answer to both questions is YES, the judging team will award the 0.5 bonus. The Table Captain will add the 0.5 point research bonus after the total score has been determined. This score then becomes the official score for the model entered into the AMPS scoring system.”
Seems like a lot work, but I’ve seen entries win gold or silver by .5 of a point. To be honest I rarely do this and if you watch most don’t, but there is always that one guy. If you are doing something unusual I would strongly suggest submitting your references.
So what have learned? Research for modeling serves really two purposes 1 it helps you know and understand the kit you are building. This in turn helps you build a better model. 2 doing a little research may give you a leg up in a competition.
When we were kids we didn’t much care about the details, but if we are going to be serious modelers we need to put in the time to know what we’re doing. So do a little research! Learn a few things! I think your modeling will be more satisfying if you do.
Ok class I bet you thought you were going to get to build now right? WRONG! Your homework assignment is to research the model you have selected. Your next posts are going to be about documentation. I want to see pictures, written material, and history. If you plan to use aftermarket items I want to know why. If modifications to shapes are required I want to how you plan to do it. These are the things judges will be looking for and the thing that will make you an expert on the subject you are modeling.
Next installment "CONSTRUCTION"
Alright what are you waiting for....Get to work!
Read more...
  • OFFLINE
  • Master at Arms
"We herd sheep, we drive cattle, we lead people. Lead me, follow me, or get out of my way."
General George Patton
The following user(s) said Thank You: Sherman 18
MODELING FOR COMPETITION: RESEARCH 29 Jul 2015 19:59 #2
Thanks Terry, so what happens if a judge does not accept research? We can't :smack em. Is there any discussion about the research, can you make your case or just submit the documentation and let it go?
Hank Williams Jr.
MODELING FOR COMPETITION: RESEARCH 29 Jul 2015 20:22 #3
I'll have to peruse this later .... :woohoo: :hmmm :thumbsup
"Peace is that brief glorious moment in history when everybody stands around reloading" - Thomas Jefferson
MODELING FOR COMPETITION: RESEARCH 29 Jul 2015 23:57 #4
Perfect timing as all of my projects are in a holding pattern while I wait for the paint to cure in this God-awful humidity.
  • Jeeves
  • Jeeves
  • OFFLINE
  • Brigadier
    Brigadier
Mike
__________________________________
John 8:36
Big Daddy Modeler Blog
MODELING FOR COMPETITION: RESEARCH 30 Jul 2015 00:21 #5
I will give a good example on how research can make or break a build. I started that (AWEFUL) Me323 Gigant kit from Italiari back when for the Messerschmit build.
Basically the outline of the kit was ok. Every detail they had on it though including windows, sizes, locations, ribbing and inside support struts was so very wrong I pretty much got disgusted and set it aside. I learned a lot and corrected a huge amount, but finally just said poo on it.
On the other hand the Revel Ju88-A1 that is on hiatus at the moment has some things that need correction, but overall isn't in need of much. Most of what I was doing on it was "adding" additional detailing. Some of which would be hard to see, but I wanted to do it. The Ju88-A4 in the stash is going to be much quicker and easier due to the research and additional stuff from the A1 build.
Finally the Millennium Falcon build that I have embarked on is becoming a research hog! Lucky for me there is a lot of info out there on the web now and it is turning a OOB project into one where a lot of parts go in the spares while I make new stuff. Lucky (or not) I can focus on areas as I receive the parts. Again learning a lot more about fabricating good plastic parts, and soon, making stuff and how to light it in new and unique ways. The info I have dug up in the last month is about 50x as much as I had going into the project. I have 23 more months to go after tomorrow. :bangs head :frantic :gogo
MODELING FOR COMPETITION: RESEARCH 30 Jul 2015 07:42 #6
:frantic
Another well done installment MrT
Your killing me as I want to start sticking plastic :zen :zen :zen
"Damn they made me put out the candle"
MODELING FOR COMPETITION: RESEARCH 30 Jul 2015 07:42 #7
Ok great stuff Terry ... I'm doing my research as We type ... I want to do a great Job on this I think I have a die cast Dauntless in my stash that need a eye cast on it ... :pilot :pilot :pilot
MODELING FOR COMPETITION: RESEARCH 30 Jul 2015 08:34 #8
Well as much as we would like to punch out the judge I don't think that would foster good will. At least you won't here them say "you should have provided documentation." As a judge I can say we read that stuff and usually ends any argument. Remember IPMS judging is all about how well it's built. Historical accuracy only comes into play when all the other hurdles have been overcome.
Again we are exploring the idea that we can use the contest rules to become better modelers. There is no "silver bullet" against a dumb#$% judge.
B)
  • OFFLINE
  • Master at Arms
MODELING FOR COMPETITION: RESEARCH 30 Jul 2015 09:01 #9
Dang-it this Slow But Deadly will be built as a 4 version ... with the twin guns I think, I already have the Squadron Dauntless book in the Basket. :woohoo: and Have been looking on the net for Info on the invasion :captain ... Now I need to go and look at the rules again as I tried to join the closest IMPS group and they suggested I open up the Hunt County division, so there may be a new sub-division starting soon ... :soldier :pilot :captain
Last Edit: 30 Jul 2015 22:09 by Swordsman.
MODELING FOR COMPETITION: RESEARCH 30 Jul 2015 15:41 #10
So you want me to research some Cougars? I think I did enough on the Cougar in that spring break I had in Cancún way back when.... I won't tell you the sort of AM I picked up....
MODELING FOR COMPETITION: RESEARCH 30 Jul 2015 16:19 #11
:rotf
  • OFFLINE
  • Master at Arms
MODELING FOR COMPETITION: RESEARCH 05 Aug 2015 10:10 #12
My research is coming along ... I admit since being a :geek all my life ... and only watching a few War Movies I've been behind but ... I'm working on all this stuff ... One thing I do try to do is work on all facets of this styrene hobby ... I was gone for awhile ...but I'm back & I really love all the new stuff (aftermarket) ... :woohoo: :thumbsup :woohoo:
  • Page:
  • 1
  • 2
Time to create page: 0.221 seconds
