Modelers Alliance Logon
Modelersalliance Tip Jar
HGW Models After Market Sets for He-111 & Ju-88
HGW came onto the scene a while back with seat belts made of a micro mesh. This material maintains its shape and colouring yet can be crumpled up and made to look used. The belts require cutting with a sharp blade and then threading through the PE buckles. I have been using another vendors belts up to not but very much wanted to try these ones. I got the added benefit from the two sets I bought of getting seats etc in resin at the same time. The set I will look at here is for the He 111 in 1/32.
box front
The mail wasn't kind to my sets packaging but everything inside was just fine. I checked out the contents and found resin seats to replace the plastic ones, resin cushion for the bomber, seat belts for everyone, PE, and a nice 8.5 x 11 inch printed instruction sheet in colour.
everything
The instructions are basically pictures with a small write up on the right side. They look very self explanatory and easy to follow.
instructions
The parts look well done and only slight flash is present. Should be a cinch to clean up.
seat1
parts
On the Ju 88 set I got, they also enclose two different types of wood decals to simulate the wood floor board for the bombardier. I already have my eye on a really nice Gotha super detail set with seat belts, masks and pe to soup up the incredible WNW ktis.
These look to be very high quality materials and I cant wait to give them a shot. I did try and unravel the side of the seat belt square of material but it wouldn't. I'd recommend these absolutely. I got mine from Ebay, but here is their web site which also has an estore.
http://www.hgwmodels.cz/
As you can see from their site there are a lot of exciting products to choose from.
